Post Reply
Thread Rating:
  • 2 Votes - 5 Average
  • 1
  • 2
  • 3
  • 4
  • 5
Cleaning Carbs
26/11/2011, 14:00
Post: #91
RE: Cleaning Carbs
Unison?
That could end badly.
Find all posts by this user
Quote this message in a reply
26/11/2011, 14:04
Post: #92
RE: Cleaning Carbs
Can I watchBig Grin
REALLY? [Image: duffman.gif]
26/11/2011, 14:26
Post: #93
RE: Cleaning Carbs
or should i say, coordinatively? hehe, crap...I even got the wrong hose size, decided to replace them midway during assembly
27/11/2011, 03:25
Post: #94
RE: Cleaning Carbs
okay...back to page 1 of thread...not even the slightest hint of life...might have to replace carb bowl gaskets...should i buy genuine stuff or fabricate from gasket material paper?
27/11/2011, 13:29
Post: #95
RE: Cleaning Carbs
Is there petrol leaking from the bowls??
MC19 frame needed. PM if you can help me out Head Bang
28/11/2011, 09:53
Post: #96
RE: Cleaning Carbs
(27/11/2011 13:29)TRUMATIXS Wrote:  Is there petrol leaking from the bowls??
As honda recommends to replace all seals, gaskets, circlips, etc if removed
Quote:Replace gaskets, O-Rings, circlips and cotter
pins when they are removed.
(27/11/2011 03:25)paparoach Wrote:  okay...back to page 1 of thread...not even the slightest hint of life...might have to replace carb bowl gaskets...should i buy genuine stuff or fabricate from gasket material paper?
http://cbr250.com/forum/thread-98.html
01/12/2011, 15:50
Post: #97
RE: Cleaning Carbs
Yeah they say that... But it's pretty easy to see if the o-ring is damaged.. But I'm only talking specifically of o-rings. You should always replace gaskets and seals if they are disturbed, not so much circlips though, as long as they aren't warped or broken, I see no problem with them.
02/12/2011, 10:43
Post: #98
RE: Cleaning Carbs
It takes a while for the fuel to make its way past the carbs once you take them apart for cleaning
Do you have spark?
Spark, air and fuel are all you need to get this party started
Real Men Ride em Nekkid
08/12/2011, 05:20
Post: #99
RE: Cleaning Carbs
so, okay, the bike runs now, but only on three cylinders, sprayed the headers with water and found out that the right-hand one most doesn't (the one near the radiator cap).
did a spark test, didn't remove the plug, just got a spare one then checked...none...then grounded it properly, good spark...
now, where to? do you think the ignition coil's crappy?
by the way, all of my plugs i replaced april this year with iridiums, i dunno if that could be it...
03/03/2012, 11:23 (This post was last modified: 03/03/2012 11:26 by cyclonepoker.)
Post: #100
RE: Cleaning Carbs
Quote:RE: Cleaning Carbs
when i attempted this, i couldn't undo the screws.
i think a couple of them are quite damaged
[Image: attachment.php?aid=224]
how do u get them off coz i fuct all my up coz i didnt hav the best tool 4 the job i just made them worst but they were dam hard ne way ????
Post Reply
Forum Jump:
User(s) browsing this thread:
Contact Us | Honda JDM CBRs | Return to Top | Return to Content | Mobile Version | RSS Syndication
