How to Change The Oil Filter.
06/06/2010, 10:01
(This post was last modified: 09/06/2010 07:45 by CBRPOWER.)
So you've removed the oil filter assembly from the engines sump like this:
![]() Remove old filter and retain the metal washer on the bottom side of the filter. ![]() Remove old seal from oil filter cap. ![]() Remove old seal from oil filter drain bolt. ![]() Install new seal on the oil filter cap, (lube the seal with a small amount of new oil). ![]() Install new seal on the oil filter drain bolt, (lube the seal with a small amount of new oil). ![]() Install the old washer in-between the oil filter and spring, ![]() Soke the new oil filter in fresh oil then, Install the new oil filter (Writing on the filter faces up). ![]() Done! Ready to install back into the sump! Electrical Engineer/Cable Guy/Maker of Electrons 4 wheels move the body, 2 wheels move the soul. |
07/06/2010, 15:40
RE: How to Change The Oil Filter.
Great thread CBRpower !!!
Many people prefer to soak the oil filter in fresh oil before they install it.... me being one of them cause I dont want my engine to starve off oil for even a minute. Only the best for my baby :-) Real Men Ride em Nekkid
09/06/2010, 07:46
(This post was last modified: 09/06/2010 07:47 by CBRPOWER.)
(07/06/2010 15:40)K916 Wrote: Great thread CBRpower !!! That's a very good idea, ill do that next time thanks matey!
09/06/2010, 09:56
do you guys have the part number for the rubber seals?
09/06/2010, 10:33
when i went to Honda and asked for a oil filter for the mc22, it came with the oil filter, and the 2 oil seals in one sealed bag.
09/06/2010, 13:29
kewl! hmmm, hope the same applies here in the Philippine market...
09/06/2010, 16:21
(09/06/2010 13:29)paparoach Wrote: kewl! hmmm, hope the same applies here in the Philippine market... Parre, kumusta ang buhay? Quote the part number that is visible in CBRPower's first thread above... it'll have everything you need Real Men Ride em Nekkid
10/06/2010, 04:59
(This post was last modified: 10/06/2010 05:01 by NSCB.)
(09/06/2010 13:29)paparoach Wrote: kewl! hmmm, hope the same applies here in the Philippine market... i've already asked around....the filter is available in most Auto Supply shops...with regards to the rubber seals, i guess we need to buy them separately from stores that sells gaskets & o-rings... (09/06/2010 16:21)K916 Wrote:(09/06/2010 13:29)paparoach Wrote: kewl! hmmm, hope the same applies here in the Philippine market... @K916 are you from the Philippines too? |
10/06/2010, 06:14
What happens if your missing the washer?
10/06/2010, 06:31
When i bought my filter the guy recommended i change the washer as well, so your local honda dealer should have them.
Failing that, i guess you could any old washer with the same diametre and thickness. |
| Problem with oil filter change! | H-on-daWay | 12 | 514 |
02/04/2012 07:14 Last Post: mm.kay |
![[Image: 1.jpg]](http://i854.photobucket.com/albums/ab107/cbrpower/1.jpg)
![[Image: 3a.jpg]](http://i854.photobucket.com/albums/ab107/cbrpower/3a.jpg)
![[Image: 5a.jpg]](http://i854.photobucket.com/albums/ab107/cbrpower/5a.jpg)
![[Image: 4a.jpg]](http://i854.photobucket.com/albums/ab107/cbrpower/4a.jpg)
![[Image: 5b.jpg]](http://i854.photobucket.com/albums/ab107/cbrpower/5b.jpg)
![[Image: 4b.jpg]](http://i854.photobucket.com/albums/ab107/cbrpower/4b.jpg)
![[Image: OilFilterDiagram2.jpg]](http://i854.photobucket.com/albums/ab107/cbrpower/OilFilterDiagram2.jpg)
![[Image: 6.jpg]](http://i854.photobucket.com/albums/ab107/cbrpower/6.jpg)
thanks matey!
