  • 1 Votes - 5 Average
MC22 Fork Oil & Seal Replacement
07/06/2010, 08:52
Migrated from old forum..
Quote:Originally posted by Harry
Fork Seal replacement 101
Tools you will need before you start.
12mm spanner
14mm spanner
6mm allen key
Rearstand and Frontstand preferable (of the headstem variety)
10w or 15w fork oil
Replacement fork seals
Rags rags rags
2 cans of degreaser
**** Thanks have to go to Stealthassasin for loaning me his bike for the project!!! **** he tells me his bike never felt better!!
Instructions
Take One CBR250RR
[Image: 001.JPG]
Remove allen bolt on front, 3 allen bolts from each side of the nose cone and remove mirrors. Pull front fairings off half way and
then disconnect front indicators
[Image: 002.JPG]
Remove bolt which holds brake lines in place
[Image: 003.JPG]
Undo two 12mm bolts which hold instrument cluster to mainframe
[Image: 004.JPG]
To leave your cibby lookign something like this
[Image: 005.JPG]
[Image: 006.JPG]
Undo 12mm bolts which hold in left and right brake calipers and slide off disk being careful not to chip the paint on your wheel
(you can slide a piece of cloth between the caliper and wheel when sliding off)
[Image: 007.JPG]
Loosen 12mm pinch bolts on left of bike (when looking from the front to the back of the bike)
[Image: 008.JPG]
About now you want to place the bike up on stands. Rearstand is a must, and if you have a frontstand it makes life MUCH easier. I
used PeeDz' stands, so if you need to get in contact with him please click below link
http://www.cr-x.org/cbr250/forum/private...me=Peidaan
[Image: 011.JPG]
If you dont have a frontstand click below to view Eclipze's "how to prop a bike up from the sump tutorial
http://www.cr-x.org/cbr250/forum/topic.a...C_ID=23117
Once it's up with no wieght on the front wheel undo main bolt which holds front axle in place
[Image: 009.JPG]
Loosen right hand pinch bolts
[Image: 010.JPG]
Remove front axle and remove wheel leaving the bike looking something like this...
[Image: 012.JPG]
Remove Mudguard (sorry no pic of that!!!)
Loosen Allen Bolts on upper triple clamp to releive pressure on the fork cap
[Image: 012a.JPG]
[Image: 012b.JPG]
If inserted, remove the two black covers from the tops of the two fork caps
[Image: 012c.JPG]
leaving the caps looking as follows
[Image: 003.JPG]
Insert 17mm Allen key took and loosen fork cap
[Image: 013a.JPG]
On left fork, undo 12mm bolt which holds in clipon
[Image: 015.JPG]
[red]READ NEXT STEP BEFORE PERFORMING!!![/red]
Undo 14mm bolt on lower triple clamp but hold onto the fork at the same time as it may slide out!!!
[Image: 016.JPG]
[Image: 018.JPG]
Undo 14mm bolt on lower triple clamp for right fork
[Image: 019.JPG]
In order to remove forks completely a circlip needs to be taken off the forks which can be undone by simply using your nails to
open and slide off fork leg as follows
[Image: 020.JPG]
[Image: 021.JPG]
One both of the circlips have been undone, simply rotate the fork in a clockwise/anticlockwise motion whilst giving it slow
downward pressure until for fork comes out, leaving you with two of the following
[Image: 022.JPG]
Use your 17mm allen key to remove the fork cap [red]*Note there may be a bit of force and the cap may spring up so hold it firmly.
The pressure is not one of those, dont hold the cap and it will hit the international space station type forces, more a oh crap
where'd that f**ker of a cap go.. i know it fell beside me somewhere....[/red]
Once undone you will reveal the spacer, a tube of approximately 15cm in length. pull this out and blow it will be a washer, and
then below that the spring.
Below is the top of the fork spacer tubing
[Image: 023.JPG]
Pour out the oil making sure you catch the spacer and spring.
Once out you will see the following
[Image: 024.JPG]
You can see here the spring, the spring spacer and the washer. Note the colour of the oil which even on this aussie delivered bike
is starting to turn black and sludgy. The oil used SHOULD be a honey colour and not have a horrible odour. For those with grey
imports you will find your oil will actually be black and somewhat mercury like in colour.
Next step is to remove the valving and fork seals. To do this there is an 6mm allen key which holds in the valving unit to the
bottom of the fork as seen in the following two pictures. *this is looking from the bottom of the fork to the top, the axle pinch
bolts will need to be removed here.
[Image: 025.JPG]
[Image: 026.JPG]
The method I have to undo this bolt is to have the fork leg sitting on the ground with one foot on the fork. ie on bended knee with
the fork leg under your front foot. Insert the allen key and use every single piece of energy you have to loosen the masses of
thread locker that has been used here from factory. Be careful of people standing behind you here as you may let out a little
muscle straining fart as you try to undo this bolt. I'm not kidding here when I say this is the hardest bolt you will possibly EVER
have to undo. Once you ear a mighty crack followed by the screaming as you realise you have just skinned your knuckles you can sit
up knowing you have undone the bolt... careful here not to thread the allen bolt.
Once you have applied liberal amount of antiseptic to your hands, you come to the easy part. Pull the fork tube apart and while you
are giving it a bit of outward pressure continue to undo the allen key. If you dont put pressure on the fork leg the allen key will
just turn on itself. You will eventually feel it let go alltogether and you can get the bolt out.
Once you have taken the bolt out you will need to remove the dust cap to reveal the circlip which holds the fork seal in place. If
you look down the staunchion you will see a circlip which holds the fork seal in place.
[Image: 027.JPG]
Use a flathead screwdriver to remove this circlip.
Once the circlip is out, hold the fork lower and staunchion firmly in either hand and pull them apart till it hits the stops. You
will need to use a bit of force here. See pictures below
[Image: 028.JPG]
[Image: 029.JPG]
You will have to do this a number of times and eventually the fork lower and stunchion will come apart leaving you with just the
staunchion looking something like this
[Image: 023.JPG]
Looking at this photo of the staunchion you see the following from left to right. Note the left is the top of the fork leg and the
right is the bottom. First you have the fork seal, then a washer followed by the guide. That's all there is to it.
Pull the old seal off remembering which side of the fork seal is facing up (this is useful when putting on the replacement) and the
washer and guide and this is the time where you degrease the crap out of everything clean it up and let it all dry.
As you can see in the following photo
[Image: 031.JPG]
The staunchion has some light surface rust on it. To get rid of this, use some fine emery paper (im talking 1500 or 2000 grit wet
and dry) and give it a light sanding till the surface rust is gone. If you have bent or chipped staunchions you can buy new ones
for approx $220 at any honda dealership.
Once everything is clean and dry it's time to reassemble. Get your fork lower and staunchion and slide the staunchion back into the
lower. If when you disassemble the forks you see a small thimble like piece of metal, this goes in the bottom of the staunchion
before you slide it into the lower. Once the stanchion is temporarily in place, slide the small spring down the fork tube, followed
by the valving with the pointy side down then screw into place. You may need to temporarily slide the spring and spacer down the
fork to put pressure on the valving as you tighten the allen key.
[red]*** Remember here to use thread locker on the allen key before you screw it in ***[/red]
Also note how tight the allen key was when you took it out. So it may require a bit of force to tighten it aswell!
Once the allen key is tight, you can remove the spacer and spring.
The next part is somewhat tricky. The way I do this probably isn't the correct way but it works for me.
Get some of the new fork oil and wipe it over the fork guide. Slide the fork guide over the staunchion and let it get down into the
lower fork. I now use a flathead screwdriver and hammer to gently tap the fork guide into place as follows.
This may take some time and it's pretty much a case of, a couple of light taps around in circles. The fork guide will slowly slide
into place. Once it is flush in it's spot put the spacer ontop.
Once this is done you have to slide the new fork seal onto the fork stanchion. You have to be VERY careful here not to cut the fork
seal or you have to replace it. The way I do it is as follows. Get some cling wrap and fold it over itself once and then sit it on
the top of the staunchion. Get some new fork oil and wipe some on the fork seal and on the top of the fork and slide it on and down
into place.
[red]*** Make sure you put the fork seal on the correct way here. ***[/red]
You may need to use the old hammer and screwdriver technique here again to get the seal to sit properly. Again light taps and don't
damage the seal. You need to get the seal down enough so that the circlip you took out can sit back in it's seat. Once the circlip
is in, put the dust cap back on, slide the spring in, followed by the washer and followed by the spacer. To end up looking like
this.
[Image: 023.JPG]
Pour in 383ml of your chosen weight of oil. I found the 15w works a treat and is not too stiff.
If you want to do the 20c mod, this is where you would do it. Put 2x 20c pieces on the top of the spacer and put your fork cap on
and tighten.
Before placing the forks back into the bike, put down on the ground and compress a few times to get the oil circulating through the
valving... you will hear air moving through the valves which is normal. This will go away as the air settles and comes to the
surface.
Once this is done, slide the forks back into each respective leg and do the removal steps in reverse order to tighten everything
back up.
And there you have it. New fork seals!
Enjoy!
[size=1][blue]
Cerby: ive never been to a party where the guys were so comfortable with blow up dolls!
PeeDz: Why.. How many parties have you been to which have had blow up dolls?
[/blue]
[/size=1]
08/06/2010, 17:31
RE: MC22 Fork Oil & Seal Replacement
Harroot, I can recognise you just by looking at your Hairy arms ;-)
Real Men Ride em Nekkid
20/06/2010, 22:17 (This post was last modified: 20/06/2010 22:18 by isRR.)
adding this here as per request:
wish these were available when i had my cibby...
Link here:
[Image: preload.png]
More info here: http://cbr250.com/forum/thread-600.html
My '07 6RR build: Click HERE
25/08/2010, 03:30 (This post was last modified: 25/08/2010 04:35 by Mr5un.)
i had a leaking fork problem.
i used your guide to pull it apart; hence thx, though i don't have any stands.
the thing is apart from degreaser i also used turp to clean my seals and parts coz the seals were leaking a lot.
now i've fixed this problem; does anyeone know whether or not i've seriously damaged any parts esspecially the seals?
also i noticed some ppl say a 20c coin fits in the fork; i've found it seems a bit small and a 50c coin would be a better option.
any objections?
thx
05/12/2010, 08:39
thanks for this guide, it helped alot while doing mine.
however one thing did come up in conversation while doing this if your using degreaser to clean everything, doesn't degreaser break down oil? i wouldnt think this would be something you'd want to happen to your fresh new fork oil.
can anyone correct or confirm this?
10/01/2011, 03:22
(05/12/2010 08:39)crazylegs Wrote:  thanks for this guide, it helped alot while doing mine.
Bump
[Image: epic-win-photos-win-ref-slide-win.gif]
10/01/2011, 07:28
If it bothers you just wipe everything with clean rags, with or without the degreaser.
10/01/2011, 08:21
it washes off in water. you wouldn't put it back together while still dripping with degreaser.....
11/01/2011, 10:08
I wouldn't wash it in water either.
11/01/2011, 13:38
Clean using whatever method you want, but finish off with a wipe of carb cleaner or brake cleaner. They remove pretty much everything and evaporate away. The main difference between the two is that brake cleaner leaves nothing behind, carb cleaner might leave some residue, which in the forks would be no big deal (brake rotors are a different story).
Oh yeah, make sure you wear gloves....these products are nasty!
Does this bike make my ass look fast?
