stuffed handle bar / bar end - solution?
30/01/2012, 13:34
buggered up my bar end / handlebar a while back and keen on getting it fixed. any ideas in fixing this? or new handlebar and the gadgets inside it?
[Image: img0065wj.jpg]
thanks guys
Maromba
30/01/2012, 13:36
RE: stuffed handle bar / bar end - solution?
i know how to get the internal out but my way involves breaking it......:/
30/01/2012, 15:35
Is there no threads left on there to screw in the bar end bolt?
Mine was also broken but luckily had enough threads left for me to screw in the bar end bolt. Once and if you can get the bolt in there just pull at it with a pair of pliers. As far as I know the only thing holding it tight in there is some rubbers so it may help to spray some wd40 to get it to slide out easier.
30/01/2012, 23:10 (This post was last modified: 30/01/2012 23:11 by akeizm.)
Not sure how the 250's bar ends are designed but on my 954 the little metal ring inside the bar is held in by 2 little triangle teeth, if you bend them back in or break them off the whole bar end would come out. The 2 teeth were about 20mm in from the edge of the bar.
[Image: 954.jpg]
31/01/2012, 01:53
Try get the screw out. If you can't then take out the whole metal rod out of the handlebar and replace it with a new one. They cost $24 from Honda.
http://www.cmsnl.com/honda-cbr250rrn-mc2...t/F05.html
Item 7 is what you want
03/02/2012, 22:28
My RHS won't screw out either, i'm lucky it's stuck in there and looks normal LOL
03/02/2012, 22:42
extractor?
I got rid of mine by drilling the whole thing out then using hooks to remove it.
03/02/2012, 23:21
I would just buy an ebay bar end pair with the squishy rubber thing to hold em in (generic bar end) and remove that with a drill, whackometer, and pliers Big Grin
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
04/02/2012, 05:39
I drilled mine... its basically a dynabolt... found some replacement at bunnings !!!
04/02/2012, 12:28
+1 On drilling it out
