carb overflow, one cyl not running
05/02/2012, 11:14
Post: #11
RE: carb overflow, one cyl not running
(05/02/2012 11:11)Humbug Wrote:
(05/02/2012 07:58)Jashdown Wrote:  It says 7mm, why would you then put it to 8mm? That's like torquing a head bolt to 50Nm when it says 40Nm.
other way around... the fuel level in the fuel bowl will be lower if set to 8mm instead of seven... as you measure it upside down.
Though I would set it to 7mm... you will not solve your overflow problem that way and you will cause the carb to run slightly leaner... just get your arse to supercheap, get some carby cleaner and clean it properly... you've wasted time taking them on and off already... so just clean them once and be done with it.
I know, it was an example.....
Get new o-rings while you're at it.
06/02/2012, 02:59
Post: #12
+1 to orings
keep an eye out for split bladders on the sliders (under the top cover of the carb) also if the bowl seals have split, replace those too.
after that, make sure you balance the carbs otherwise they will still run like shit regardless of how clean they are.
[Image: sigsmallr.jpg]
09/02/2012, 05:30
Post: #13
If you get really stuck pop round and I'll fix it (or tell you what you need to get before progressing) for a slab of beer Big Grin Rory 0448833823
09/02/2012, 10:18
Post: #14
Well i did clean them with some good old fashioned carby cleaner and it is sweet now XD
09/02/2012, 10:37
Post: #15
(09/02/2012 10:18)venkar Wrote:  Well i did clean them with some good old fashioned carby cleaner and it is sweet now XD
Thanks for wasting all of our time noob
  Carb gas/oil overflow (?) 1988 MC19 Greasemonkey 1 137 26/03/2012 03:48
Last Post: Lane
